js058515
Thank You Brushless Gods!
js058515's Avatar
02.28.2009, 09:58 PM
Hey Tekno,
With the 3 shoe adaptor I know that different clutchbells fit better than others as some fully cover the shoes and some don't. I have Tekno clutchbell and I compared it to a mugen one. The mugen one has a slightly shorter skirt, will this be a problem? It still looks like it will cover the shoes, but I just wanted to know if has tried other brands of clutchbells. Thanks.
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
teknorc
03.01.2009, 01:57 AM
Originally Posted by js058515 View Post
Hey Tekno,
There shouldn't be any issues. The new clutch has a lot of surface area and plenty of grab. You could try shimming up the clutch shoes with some small washers or clutch shoe shims. Give it a try though, it should be fine.
Tekno RC - Performance Parts
Ryu James
Ryu James's Avatar
03.06.2009, 08:43 PM
so i got the new 3shoe clutch a little over a week ago and it ran way smoother and much better than the first version 2 shoe. i ran it for about 15 minutes or so but still preferred the longshank direct drive setup. maybe i am just so used to that now. i can see how the clutch could be favored though with the ability to "tap" the throttle for low speed maneuvering around corners. unfortunately i had some parts stolen at the track recently, including my clutches, so i cant run it even if i wanted to now.
but i did have a question. when i put the clutch on, my front tires were really ballooning up huge when i accelerated. i did not think this was due to the clutch at all but when i put the pinion back on they only ballooned about half as much and had to reach much higher speeds to start ballooning whereas with the clutch it was almost immediate. can anyone explain why this would happen? why would the clutch cause more ballooning than my pinion?
also, how hot should the clutch be after running? i had my gear mesh set just normal but when i went to take the clutch off it burned me! is it normal for it to be 150*? or is there something i should have done differently?
Jammin SCRT10 Neu 1512 1y
