sepukku
12.07.2005, 10:21 PM
Originally posted by RC-Monster Mike
Squee's estimate should be pretty close to upgrade to CF. Maybe even a little high. Basically, the 4 upper plates and the lower plate are the CF parts to be switched out.
hey mike would it be possible to get the lower plate from you without the cutouts for the batteries...since i need to mount a motor and gas tank and stuff...those cutouts will probably hinder some of the mounting possibilites.
thank you for your time.
Dafni
Dafni's Avatar
12.08.2005, 03:39 AM
I doubt it, sepukko. This would require special work from Gorilla and might take alot of time. I wonder what Mike will say.
BUT, it would be pretty easy for you to make your own chassis plate, useing the gorilla plate as a template. The hole pattern is not complicated.
