Here is a close up so you can see the ESC and motor. Notice I also added a 40mm fan that mounted perfectly to the esc tray that blows directly down on the motor.
And here I added XL axles to add a little width and the dog bones are alot better.
So now I am waiting on the CEN diffs to arrive. When I put in the diffs with 14t pinion and 47t spur the complete gear ratio is 16.9 which is very close to the flux. Also waiting on the LST shocks. When I get it all together I will add final pics. Any comments or questions are welcome. :)
Looking good so far. Is this the stock tranny, spur and slipper out of an e-savage? If so ... be carefull with slipper setting. Even with a less powerfull motor (Kontronik FUN 600/2500) powered by 12 cell Nimhs (around 1000 Watt peak) my spur started to wobble after a few runs due to the heat caused by the slipper (running a n otherwise stock e-zilla). The 2200kv castle motor will melt your spur if your slipper is set to loose. Your tires won't be easy on your tranny either. The e-savage uses way lighter and smaller tires. But i guess you are already well aware of this facts.
Wheight distribution reminds me of the savage flux which features a somewhat longer wheelbase. Expect some wheelies ;-)
Do you plan on running the castle combo with nimhs or can you fit lipos inside the stock battery holder?
I will run it with LIPO only.The lipos fit fine due to the TVP's being spaced out further due to the conversion. Im going to start with 2 4s packs. As for the spur/slipper, in the pics it is the stock e savage stuff 66t spur in 32p. But thos are older pics and it now sports a steel GP savage spur that is 47t and mod1 pitch. The gears in the center are stock but I have a full set of custom hardened steel ones in the works. Gonna run it with the stock ones first just to note on how long they last.
