othello
HV basher
03.06.2009, 05:25 AM
Looking good so far. Is this the stock tranny, spur and slipper out of an e-savage? If so ... be carefull with slipper setting. Even with a less powerfull motor (Kontronik FUN 600/2500) powered by 12 cell Nimhs (around 1000 Watt peak) my spur started to wobble after a few runs due to the heat caused by the slipper (running a n otherwise stock e-zilla). The 2200kv castle motor will melt your spur if your slipper is set to loose. Your tires won't be easy on your tranny either. The e-savage uses way lighter and smaller tires. But i guess you are already well aware of this facts.
Wheight distribution reminds me of the savage flux which features a somewhat longer wheelbase. Expect some wheelies ;-)
Do you plan on running the castle combo with nimhs or can you fit lipos inside the stock battery holder?
JEDI
03.06.2009, 05:35 AM
I will run it with LIPO only.The lipos fit fine due to the TVP's being spaced out further due to the conversion. Im going to start with 2 4s packs. As for the spur/slipper, in the pics it is the stock e savage stuff 66t spur in 32p. But thos are older pics and it now sports a steel GP savage spur that is 47t and mod1 pitch. The gears in the center are stock but I have a full set of custom hardened steel ones in the works. Gonna run it with the stock ones first just to note on how long they last.
othello
HV basher
03.06.2009, 05:56 AM
Perfect. Then you are well prepared to unleash the power ;-)
