mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
03.08.2009, 09:12 AM
Originally Posted by squeeforever View Post
@Mistercrash- Another option, and cheaper, is the Tekno kit. The RD Racing kit is something like $200 for the knuckles, axles and hubs, and the Tekno is only $80. Just a alternative to the RD and M2C.
You're talking about the axle carriers right? The mod I did are for the Ofna adapters, I didn't do any mods to the carriers. I used the modded Ofna adapters on the old TRX axle carriers, the RPM axle carriers, the RD Racing axle carriers and the new TRX carriers introduced on the Platinum Edition Revo which I'm still running now. The modded Ofna adapters end up costing under $30 total not counting my time. Time spent in my garage is priceless
No brain, no headaches.
squeeforever
squeeforever's Avatar
03.08.2009, 03:58 PM
I was just referring to where you said the most durable and slop free was the RD Racing with the 8mm axles. I was just mentioning the new Tekno kit that is pretty similar, just uses plastic knuckles instead of the aluminum RD uses. Alot cheaper than the RD kit, since its the most expensive, by far.
mistercrash
Guelph, Canada, eh!
03.08.2009, 04:42 PM
Ok I get it. I read slow and you must have typed too fast so that's why I got confused I never tried the Tekno system, it looks interesting but I'm waiting on feedback of other people that have been using them for a while to find out if the aluminum rings they use on the carriers will really prevent the pillow balls from popping out. But right now, the Ofna adapters I modded and the TRX carriers with steel rings have been doing so well that I don't feel like changing anything.
