jacobsjo87
03.09.2009, 07:54 PM
I have a DX3R. I think I like the 3500 since it is so small also. I'll most likely go with it. The DSM2 is suppose to have lower latency, but the 3500 says it has the same latency as the pro models. Does pro model mean DSM2?
skellyo
skellyo's Avatar
03.09.2009, 08:00 PM
No, the Pro is not the same as the DSM2. I can't tell you what the difference is, but I know that even when using a Pro Tx module, you cannot use a DSM2 Rx.
Also, look around, you'll find the SR3500's just a tad bit cheaper than the SR3100's.
