Eagletree results: Aftershock + 6S Zippy + 2200kv Castle
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
Eagletree results: Aftershock + 6S Zippy + 2200kv Castle - 03.11.2009, 08:18 AM
I may be hitting the battery a bit hard.
johnrobholmes
johnrobholmes's Avatar
03.11.2009, 08:40 AM
What pack specifically?
---JRH---
sleebus.jones
03.11.2009, 08:42 AM
It's the 6S Zippy H 5000MAh pack. 20C-30C
Last edited by sleebus.jones; 03.11.2009 at 12:43 PM. Reason: Said it was 4000MAh before, oops!
johnrobholmes
03.11.2009, 08:51 AM
So they hit 3.2v/cell at 38c burst? Not bad really, did you pull a temp from the pack at any time?
---JRH---
sleebus.jones
03.11.2009, 09:24 AM
No, just used the hand-o-meter. It was barely warm. The motor temped at 117, and the pack wasn't near that, I'd say maybe 100 - 105?
johnrobholmes
03.11.2009, 09:35 AM
.1 second sample rate?
---JRH---
sleebus.jones
03.11.2009, 09:50 AM
Yep. The only way to fly. :) I can give you an excel data dump if you want, just will have to be tonight.
jzemaxx
03.11.2009, 10:09 AM
WHAT!!!...that is imposible. They are suppose to be crappy batteries that make MMM's die
Great test....would love to see the higher 5000 MAH batts. They are wonderful batteries....
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
sleebus.jones
03.11.2009, 12:46 PM
Just a bit of an amendment to what I said before. I've got the Zippy H 6S 5000MAh pack.
So I wasn't pulling 38C, it was more like 30.8C, which makes me feel a lot better, and also explains much better why the battery was that cool under that kind of load. At any rate, it's a stupid fast setup with boatloads of power that runs cool. What more could a person want? :)
lutach
lutach's Avatar
03.11.2009, 01:48 PM
Good one jzemaxx. I would love to see how your HW esc does on the long run as they are basically similar to the MMM. If they don't go out like the MMM, then Castle has to look at what is causing them to fail.
jzemaxx
03.11.2009, 03:59 PM
Well we ran the HW150A last night with the CC/Neu 2200 on 6S for around 30 mins doing some speed runs gearing the piss out of it....54/24. Never gave up!!!....did get a little hot though.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
Byte
03.11.2009, 04:18 PM
Any idea what kind of speeds you get, and which gearing are you using?
I'm asking this because I'm also converting a LST, (Actually same as Aftershock) the only thing I need are the batteries. I also have a MMM 2200kv combo, and will run it on 6S.
sleebus.jones
03.11.2009, 05:10 PM
I believe that I'm geared 24/66 and the speed is in the 40mph+ range. Plenty fast for my use. I was launching it into outer space with 5S; I can't even imagine how high/far I'd get with the current setup. :)
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
03.11.2009, 08:56 PM
Nah, your not hitting the pack hard. You're only using 9 amps on average. I average about 18 amps with my 2650 motor in my 8ight and I am easy on the throttle. Wait until you gear high enough until it takes 50 amps just to maintain a constant speed. Then you are really testing your pack!
Area 52 Ranch Raceway
T.R.C.R.
sleebus.jones
03.11.2009, 09:01 PM
That 9A on average is misleading, because there's a fair bit of dead time in the graph that you don't see...it's averaging your draws over your total runtime. I don't pay attention to it. I look to see where the middle is between the peak and the bottom, that's a more useful average draw. This setup looks to take around 50A - 60A to maintain a constant speed, I just need a large enough space to test it!
