01.27.2009, 06:00 AM
you shoult connect the mount with the chassis, with a bracket:
like that you have
-no flex at all
-the chassis turns into a heatsink
its quickly done and it works. I have two mounts, one for a bigger motor (kb45xl), all alu in L-shape, and one made of alu and carbon for a 36mm motor, which ist definately stiffer. the one for the kb killed the teeth of the center-diff due to a minimum of flex.
aluminium is less stiff then eg. glassfiber, carbonfiber, and it is possible that it is still flexing a little.
Connected to the chassis it also reduces the forces at the center-diff mount. its made of plastic, and it could flex like that very little as well.
A 16yr old with a combover
01.27.2009, 01:10 PM
i thought so too, but apparently that is supposed to be a flexing chassis, and bolting the mount to it would make handling suck
01.27.2009, 01:27 PM
hmm, allright. still, I guess the rest is still able to flex, it's just the center of the chassis. front and back wouldn 't change, I don't know.
maybe u just try it, and when it sucks, just remove the screws.
cool truggy btw!
01.27.2009, 01:50 PM
then again, for those whove seen red vs blue, theres the always the grif option(aka screw it im too lazy)
i tried to tell ben to try that when we made the mount. he was like nahh
01.29.2009, 10:37 AM
cool truggy btw!
thats alway an option Ill admit, but if it aint' broke (and by broke I mean flexing) dont fix it. and thank you :)
I dont see the mount flexing. i did a stationary test on carpet the other day, put the front wheels against the wall and gunned it. nothing moved.. with the old mount the aluminum would flex andthe pinion would walk up the spur gear until it no longer meshed and would skip.
I think i found a winner with this mount.
01.29.2009, 10:46 AM
Damn, you sure break your truggy a lot.
WARNING: May become violent.
01.29.2009, 12:32 PM
He must have alot of untamed mailboxes, lightposts and garbage cans.
RIP- Tammy (9/14/08)
01.29.2009, 07:29 PM
I think i should just dial out epa on the right side... cuz i always break the right arm...
Update -
02.04.2009, 12:36 AM
02.04.2009, 12:38 AM
That looks much better.
02.04.2009, 12:39 AM
Thanks, think i might end up getting another kyosho crowdpleaser. looks good when they fit
02.04.2009, 09:54 AM
Mini- Update -
03.12.2009, 03:17 PM
Finally got my Novak battery trays, They are pretty nice peices and definately a step above the handmade predecessors.
I turn seventeen on monday (w00t license)! and should be bringing in a decent amount of cash, RCM motor mount is next on the list, along with some new rubber and a body.
03.12.2009, 03:34 PM
433 posts and you are not done??? Wow.
03.12.2009, 03:37 PM
Its been a slow build.. Buying parts here and there.
Right now its Runnable, but not complete.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
