Jeremy1976
03.15.2009, 08:27 PM
I am running a Medusa 50 series 3300kv in my daughter's crt.5 and I run: (I am running a mm esc not a mmm esc)
1. Med. start power
2. Timing 2
3. punch control set to 20%
4. 2s 5k 20c battery
Now the esc has been running hotter that I like with this set up....150-160... I started w/0 timing and have advanced it to 2 w/a small improvement. This week I will advance it to 5 and retest. I will also drop 1 tooth on the pinion as well.
Medusa recommends for this motor 8-15 timing believe it or not.
Hmmm, I wonder where I should start????? I have a PQ 30c 2s 5000mah pack and a Poly R/C 30c 3s 5000mah pack. Got a SPC 2s 5000mah pack that is 15c too.
