03.16.2009, 08:06 AM
Does the Hyper run odd ratios else you are way undergeared...
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 10
Total Voltage: 14.8
Motor KV: 2650
Tire Diameter (inches): 4
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 4.6 : 1
Total Ratio: 15.21538 : 1
Tire Circumference (inches): 12.57 inches (319.19 mm)
Total Motor Speed: 39220 RPM
Vehicle Speed: 30.67 mph (49.27 km/h)
Effective KV Value: 2650
KT constant: 0.51 oz-in/A
