traxxasrevony
03.18.2009, 11:16 PM
now this would be a motor to put in a baja
http://www.modelmotors.cz/index.php?...e=20&line=GOLD
you would have to gear it really high. im not sure how big the spurs are but your only turning 2350 rpm even a 1:1 ratio would be too low. say the spur is 40 tooth your pinion would need to be like 50 teeth.
you would have gobs of torque tho so maybe you could even run 60/40.
