whitrzac
Can't catch this...
whitrzac's Avatar
03.21.2009, 12:44 AM
WOT!!! my motor came in today!!!
I lil on the fast side, but I'm only driving in an open field right now.
did I enter the amp draw right?? 1000 cont. watts / 14.8
cont.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 12
Total Voltage: 14.8
Motor KV: 3300
Tire Diameter (inches): 4.6
Tire Ballooning (inches): 0
Motor Current Draw: 67.56
Motor coil Ω: .004
Spur/Pinion Ratio: 3.83 : 1
Total Ratio: 12.67949 : 1
Tire Circumference (inches): 14.45 inches (367.06 mm)
Total Motor Speed: 47948.21 RPM
Vehicle Speed: 51.75 mph (83.13 km/h)
Effective KV Value: 3239.74
KT constant: 0.41 oz-in/A
Motor Torque: 0.14 ft-lbs
Final Torque: 1.83 ft-lbs
Final Power: 999.89 watts (1.3 HP)
max
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 3300
Motor Current Draw: 135
Motor coil Ω: .004
Total Motor Speed: 47058 RPM
Vehicle Speed: 50.79 mph (81.59 km/h)
Effective KV Value: 3179.59
Motor Torque: 0.29 ft-lbs
Final Torque: 3.65 ft-lbs
Final Power: 1998 watts (2.7 HP)
