Sammus
Sammus's Avatar
03.21.2009, 02:15 AM
Originally Posted by MetalMan View Post
I guess I don't understand why we need to convince you? Me personally, I have no real data to share. It's likely others here don't either, they just have their experiences. Just keep in mind outrunners in cars are still relatively uncharted which means little quantifiable information.
From my experience, the answer is presently NO. That could change if the Castle outrunners are as good as Patrick seemed to indicate they are.
You don't need to :) I guess I'm just asking to be. I just think it's a cool idea and worth exploring, but don't have the $$ to do it myself at the moment :p. So yeah, basically experiences would be good, but most people who have run outrunners have built the car for the outrunner, or changed the car significantly to run the outrunner.
Like has anyone gone from an car running an inrunner, then bolted an outrunner in its place, geared it up to a similar speed, and compared performance?
03.21.2009, 02:19 AM
Sikeston 34m has done this with his emaxx. went from a 2826 axi with 22/40 (something like that) gearing to a medusa...
I will say that 99% of people will find an inrunner preferable over an out runner in a land vehicle.
Sammus
Sammus's Avatar
03.21.2009, 02:26 AM
Sweet. Is there a thread or post about the experience? I'm not having luck finding it, I found the outrunner e-maxx thread, didn't mention any medusas though.
Sammus
Sammus's Avatar
03.21.2009, 02:27 AM
P.S. Sorry eveyone who was subscribed to this to read about castle outrunner information. I didn't mean to perform such a significant hijack.
sikeston34m
sikeston34m's Avatar
03.21.2009, 10:53 AM
Yes, this is true. There isn't a specific comparison thread about it, ya gotta read between the threads. LOL
Or just ask.
Both setups use 5000mah 20C 4S Lipo
AXI 2826/8 geared 22/40 - Great little setup. I would have to say the MOST efficient setup I have ran. Usually about 10 extra minutes of runtime than an inrunner setup. This motor will run higher gearing, but temps get "uncomfortable".
Medusa 36-60-2000kv geared 52/18 - Another Great setup. Medusa makes the best inrunners I have ever owned.
It would have been easier to compare the two if I were using an older style feigao 2 pole motor. The gap on efficiency and operating temps would have been large.
When Medusa made this line of motors, they did alot of things right. The 4 pole design is truly superior to the old 2 pole motors. I love my Medusa. A little less runtime than the outrunner, but it makes good power. This setup continues to break driveshafts.
On the other hand, the AXI setup would dominate on short track.
Mike's speed calculator shows these two setup like this:
AXI geared for 30.15 mph
Medusa geared for 33.59mph
I GPSed the Medusa setup at 38mph, so these the calculators figures are a little low.
The AXI setup tops out ALOT faster than the Medusa setup. It's quicker "out of the hole". It will yank the front end right at startup, where as the medusa comes into it's real power a little farther off the starting line.
"when sik said "A super low kv inrunner would make ALOT more torque" I thought he mean than an equivalent size/kv outrunner. Now I think I may have misinterpreted his response."
Sorry, I should have said "A super low kv inrunner would make ALOT more torque than it did before." Not to be interpreted that it would make more than the outrunner.
sikeston34m
03.21.2009, 11:21 AM
Ok, here's a showcase for you guys. Maybe you will see why I'm excited about Castle's new outrunner line.
First up is where it all began for me and outrunners. The E maxx with an outrunner directly connected to the transmission input shaft. Actually the motor shaft and the input shaft are the same.
Next up, is the Revo Direct Drive to Diff Build. Powered by a custom wound AXI 4130. It kept blowing the bearings on the RCM diffs in about 2 runs. The Ceramic Nitride bearings faired no better. Differential toughness is gonna have to catch up before this setup really works well. Show me an inrunner that explodes diffs like this.
http://www.youtube.com/watch?v=dFDrYXLkcGg
Next up is the AXI 2826/8 setup.
sikeston34m
03.21.2009, 11:49 AM
Let's talk about why outrunners have more torque.
A Medusa 36-60's armature is 15mm in diameter and is 35mm long. It has 4 VERY strong magnets, thus making it a 4 pole motor.
An AXI 2826's stator size is 28mm in diameter and is 26mm long. The ID of the magnets inside the rotating endbell is 29mm.
The larger diameter is "easier" to turn because of leverage. This is why there's a knob on the door instead of just a shaft sticking out. LOL
Take a look at my avatar. For each phase shift, there are 4 teeth of the stator energized at any given time.
This means, at any given time, there are 4 magnets in use at any given time. More Magnets, greater force.
MetalMan
MetalMan's Avatar
03.21.2009, 02:30 AM
The application argument is the most important one from my perspective.
For example, right now I am building from the ground up an outrunner-powered belt-driven truggy with no gear reduction aside from the main pulleys. The kv on the outrunner is 360, and it will be powered by a 6s Lipo.
An outrunner would spin much too fast for this design, and would require at least a pinion/spur. One of my objectives with this project is to make it as quiet as possible, not for any real reason, just because I can.
Sammus
Sammus's Avatar
03.21.2009, 02:44 AM
Yeah, that's sweet. Have you started a build thread?
