What heat sink to use on Neu?
FastXR
What heat sink to use on Neu? - 03.23.2009, 08:31 AM
Hey guys I have a Neu 1515/2.5d with a smooth can and will be using it in a truggy for racing. I would like to put a heat sink on it to try and keep things as cool as possible. What would you recommend? Does Mike make one for this?
FastXR
03.23.2009, 01:27 PM
anybody?
03.23.2009, 01:32 PM
The only thing I've seen are those heatsink/mounts on ImpaktRC. IIRC, there was somewhere else that had heatsinks for Neus but I can't remember exactly where it was.
FastXR
03.23.2009, 02:29 PM
Thanks Brian, if you come across the other heatsinks let me know please
03.23.2009, 10:20 PM
That sounds a bit rude...
Anyway- where's my cookie?
http://www.airpowernet.com/twe/produ...roducts_id=535
They seem to have changed the design a little bit since the last time I looked, but it will fit any 15** motor, might just have to trim the length accordingly.
FastXR
03.23.2009, 10:28 PM
Cool thanks Neil I likes!
Finnster
KillaHurtz
Finnster's Avatar
03.23.2009, 10:31 PM
I vote none.
Shouldn't need one, mostly dead weight, and may be insulating if its not machined really tight. Trapped air pockets will hold warm air like a coat.
03.23.2009, 10:33 PM
I would generally agree, but I guess it depends how extreme the setup is- thermal grease should solve any heat transfer issues though I would have thought.
FastXR
03.23.2009, 10:41 PM
Not really that extreme, CEN truggy on 5s with mmm, 1515/2.5d geared 46/15. I don't know that I need the extra cooling I just wanted to have all the bases covered before my first race with it coming up and unfortunately due to the weather around here I doubt that I will be able to test it on anything resembling a track. If you guys think its a waste then I wont even worry about it. What do you think?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.23.2009, 10:45 PM
On 5s you should be able to easily gear it to destroy the nitros and still stay cool.
FastXR
03.23.2009, 10:54 PM
Unfortunately its going to be a 1/8 electric race a run what you brung sorta thing, buggies, truggies and MT's so I won't have to worry about nitros I will be on equal playing ground with most others. I assume most others will be running Castle MMM combos a few of the Novaks and maybe in one or two of the new Tekins it guys can get their hands on them.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.23.2009, 11:07 PM
Most will still gear for about 40 so you should still be ok. On such an efficient motor a heatsink isn't so crucial. Try running without one first, if it gets to hot for your liking then get it.
FastXR
03.24.2009, 07:48 AM
That is what I will do then, I have a Medusa 70mm and a Fiegao 9XL both with heatsinks so if I have issues with the Neu I can switch to either of those as a backup. Thanks for the tips guys!
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
03.24.2009, 07:58 AM
Exactly what I've found out. Heck, I'm running an Aftershock, geared for about 47 MPH on 6S with the Castle 2200Kv and it doesn't want to get hot. I really doubt you'll have any problem with your setup.
phatmonk
RC carbon junkie
phatmonk's Avatar
03.24.2009, 08:50 AM
Check this out.This will fit all 15 series diameter but you will have to trim the length
http://www.tamjets.com/original/inde...1a4be5e5158230
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
