03.24.2009, 01:41 PM
Wow, I thought mine was loose with ~1/2" of sag! There's no way I can get it off without removing the end plate from a pulley.
Yeah, you adjust tension by shimming under the 4 screws holding down the front transfer shaft. Not very effective though because by the time you get the long belt right, the front is too tight. I'd rather see a simple spring-loaded idler riding on a bearing.
I was going to make one for it... I do need new belts, and the 2.5 and 3.3 use different pulleys and different belts too. I think my other belt is the wrong one (so is my luck). My front belt is just right with no shims, so I guess that I need a new center belt...
I may give the one I have a try...
03.24.2009, 03:28 PM
The only difference between the 2.5 and 3.3 belts is the front and rear belts. The center is the same since it uses the same pulley size. The f/r small pulley went from 15T to 20T IIRC, so a larger belt is necessary.
You might want to just brace the chassis. I know that the belt had a ton of play on mine until I braced the chassis. If you push down on the center belt, you can actually see the chassis flexing.
03.24.2009, 04:31 PM
This is true, I am thinking about the front and rear belts. I will rig some sort of brace up, I have a few ideas in my head, but will wait for the neu cells to come in before I do anything.
On another note, I destroyed the front belt just now... I guess I get to order a new one, or maybe check the LHS (waste of time usually). The stupid hole in the chassis at the front allowed a rock in and it jammed between the diff and the front upright/shock mount. I may add a hole in the front to allow debris out... Bad design not having a sealed front and rear belt setup... Maybe I can make something. I was thinking about a new chassis for the beast...
