I use this super velcro stuff you can get a menards and radio shack. It is like the non-furry side of regular velcro on both sides. It holds the esc on like no ones business. I would do that and a ziptie if you could.
I got some of that stuff, its clear, right?? I had a problem with it not sticking to the esc and were I want to mount it
The stuff is called 3m dual lock. It holds everything for me. You need a screwdriver to get it apart. I have seen it clear... Mine is black. If it doesn't stick to your esc, you can use some ca glue to hold it on. Make sure you're not trying to stick it to regular velcro too.
yep thats the stuff I have, I'll have to give it another try
looks like I have no choice now but to buy an RX8
rolled the buggy, flipped it over, it went 10ft then died, it was at 3leds so it didn't thermal, the BEC still works, but I have no lights, beeps, etc
it couldn't have happend at a worst time ether... people were just starting to gather around:ha: usualy stuff like this happens after a "hey watch this!!..."
