sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
12.12.2005, 10:25 AM
Heh, 20 51 and 18 cells and you had some heat problems? :D Gee, I wonder why? ;)
Yeah, I can understand the efficiencies from running higher voltage...you get the same power, with less amps, so everything should work better/cooler. Well, looks like i'll give the stock gearing a shot until it blows up. From my closest guess, it should run almost the same speeds 'cause with 16.8 volts, the 9XL gives you 35,000 RPM. That translates to 32 MPH.
From there I suppose I'll just mess with different gearing and see what kind of heat buildup I get. I wish I had access to some torque curves somewhere...I thought I've seen them someplace, but can't remember where....
Michael
