Electric Dave
03.29.2009, 09:51 AM
(Long post alert)
I took the truck down to the Pin Shop Hobbies track yesterday to run some practice laps and shake out any issues with the truck or electronics. For those of you that are not familiar with Pin Shop, the track hasn't been touched since last year. One part was pretty mangled by the snowplowing over the winter. At then end of the season last year, the track was pretty well beaten and in desperate need of a rebuild. I expected it to be rough and really just a shake down of the truck, not so much a setup or tuning day. A few guys showed up and did a great job with the raking, the track was super dry and it seemed to have loads of small pebbles and sand on top.
As far as running the truck, it is just psychotically fast. Perhaps too fast for this small track. I'm only up one pinion tooth from my gearing last year but the truck just felt much faster. There is no doubt the Losi is a fast reacting vehicle. The first pack was a little wild as I was getting to know the truck. I was pleased with the steering. I think the feature I was most impressed with was the jumping. The truck just loves to launch. Again, knowing the track is getting a complete rebuild in the next few weeks, I wasn't too concerned about handling, however I would mention that the rear end was much looser than the old CRT. The truck was just sliding all over the place. Eventually I stopped fighting it and just power-slided around the corners, it was impressive looking but very hard to control and in a race, it would be a very risky way around the corners. Once the real dirt is down and the track is built I'll work on bringing that rear end under control.
While it is great to sing the praises of something, you can get all that from the magazines, I'll mention my gripes with the truck/design. My biggest disappointment is with a flaw in Losi's design. This is the first time the Losi Truggy has 0 offset wheels so the geometry and arms are all new. In short, they rub badly unmodified. Luckily I had read about this online. A few days ago I posted in this thread that I ran it outside my house. When I did that I had not made any changes to the truck. True to form, even in the few minutes I ran around my house, I cracked a small part of one of the webbings inside the front wheel. At full lock the webbing inside the wheel will hit something, the steering knuckle or something. Before hitting the track I did the research. I took a sharpie and laid down a heavy line on the webbing, then I spun it by hand. The black ink showed exactly where the rub was on the webbing. Then I hit the dremmel, I didn't have the exact right bit for the job but I did the best I can. I also read about the rim hitting the arm in use and I can see wear from the spot that rubbed. I will also hit that with a dremmel. Apparently one fix is to use the optional Losi +2mm hubs. They won't require the wheels to be modified. Kind of bothers me that Losi, who touts their Engineering prowess all the time, would have made such a huge mistake. I'd bet that anyone running a new truck, without one of the two mods, will crack their wheel after one run. Other than that, another thing I saw online also happened, the camber links backed out in the front and rear. Fix there is copious amounts of locktight and longer screws to get into the nylon of the locknuts. I will be fixing that right away. Only other gripe is that even after just 4 or 5 runs, the rear bearings already feel not right. I have to take them out and clean them but I've read about some King Heads hubs which make use of larger bearings, I have a feeling that upgrade is in my near future.
The teething pains of a new vehicle design are not uncommon and while I sound pretty critical, I just want to help other guys reading to prepare their 8T 2.0's. I am sure this truck is fantastic and I'm positive that it will shave time off my laps. It is a winner for sure but like anything worth doing, you have to put in some time and effort to make it live up to it's potential.
