Hardstyle
Hardstyle's Avatar
04.02.2009, 01:56 PM
Hey lincpimp. I have two puffed 3s 8k MA packs. Was just wondering would you be interested in them? I really dunno what to do with them so desided to ask you..
04.02.2009, 02:05 PM
Sure, do you want to send them to me and I can examine them and see what can be salvaged?
04.02.2009, 02:08 PM
Metallover, I just recieved your lipo. I do like your wiring very "inventive".... Also thanks for the free coke coupon!!!
Should be able to get it correctly assembled this evening and get it back in the mail. Do you want a new deans plug and 13 gauge wiring? Not sure if you wanted to keep the sub 14 gauge wiring and the hxt deans knock off that is on it. I do not currently have any jst females... I do not use jst on anything so I never bothered to make adapters...
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.02.2009, 05:55 PM
I would like new wire, that wire is a little wimpy. You can do whatever with the deans plug, there's nothing wrong with the current one that I know of. That's ok about the female jst adapter too... I might have found a solution.
And make sure to enjoy that pop! Thanks for doing this for me Linc.
04.02.2009, 08:09 PM
No prob, lipo is done. New tap wires, new deans plug, new 13 gauge power wires. And new black shrink that does not look like it was applied by the blind...
I will drop it in the mail on my way home, priority of course. And thanks for the pop!!!
mohanjude
Need for speed
mohanjude's Avatar
04.03.2009, 01:36 AM
"And new black shrink that does not look like it was applied by the blind..."
I am rolling on the floor reading that - ouch.... I must say that plastic shrink is like onion skin - it just vapourises if you apply too much heat on one spot. Using a blow torch ?? even my 2 cents gas lighter blows holes in the shrink. Have to use a hair dryer to ensure even shrinkage.
04.03.2009, 01:40 AM
I figured someone with a dry sense of humor would like that!
I use a heat gun on low setting to shrink the packs. Heat the ends a bit to get them almost tight, the run sown the narrow sides, then the wider sides, then finish off the ends. Seems to produce the best repeatable results in that order...
Hardstyle
Hardstyle's Avatar
04.02.2009, 02:28 PM
Yes that would be nice Don't know where to use them though if you can save some of the cells.. Too bad C ratings..
How can I send the packs to you and is the shipping costs expensive? Have to be honest, never shipped anything to abroad
04.02.2009, 03:12 PM
Hmm intl shipping. I usually just use the Post Office and go with some sort of ground shipment. That is the cheapest, but it does take a while. I just wrap them up well in bubble wrap and make sure everything is a snug fit in the box. That keeps the weight of the package down, but keeps the packs safe.
