jsr
04.04.2009, 08:57 PM
Ok, I got almost 2hrs to work on my RCs today (that's a lifetime for me...got the baby to sleep for a couple of hours). Here's my DBX (I wanted a DST, but couldn't find a used one) converted to brushless.
Per RCM's calculator, it should go 40mph, but it seems to be doing only about 30-32mph on 3s. Still fun and fast. The Graupner motor mount has flex since it's plastic, so there's a pole piece (a long piece that was a plastic standoff I got from another truck) underneath the motor to prevent the motor from moving down as it hit bumps (thus changing the angle of the pinion to spur). The Graupner mount has to be cut where the spur is to allow for space for the spur to contact the pinion, and where the front center diff bulkhead is to allow the mount to be moved inward toward the centerline of the chassis to let the spur and pinion contact. I drilled 2 holes in the base of the mount, one rear of the motor interface and one front of the motor interface to attach the mount. The rear hole attaches through an existing hole in the chassis that I widened (to allow for adjustability toward and away from the centerline to account for different tooth/size pinions). I had to drill and widen a hole in the chassis for the front hole in the motor mount to line up. I used concaved washers and flat-head bolts underneath with nuts on the top of the chassis to secure the mount.
I'd recommend a stiffer mount, something metal. I got the Graupner mount from Offshore Electronics. Their DR metal mount would probably be better, but it would have been much harder to cut as it would still need cutting. Looking at the pics of the OSE DR mount, it would need to be right where the motor attaches to the mount to make clearance for the center diff rear bulkhead. This part would cut close to the mount hole for the motor, so you'd have to be careful and I'm not very clean at cutting with my dremel.
To fit the E-Sav wheels, you need to buy 12mm to 14mm hex adapters and drill out the center hole on both the adapters and the wheels to allow the larger spindle diameter of the DBX to fit through.
The stock springs are super soft, so I'm running Ofna yellow (which I think are Medium stiffness) springs I took off my Ofna truggy shocks. The springs now are too stiff for the oil, so I need to change oil. I plan to use 60wt and see how that is.
Because the ESC sits in the space where the RX battery pack used to go, I couldn't get a temperature reading, but by feeling around it (the heatsink), it didn't feel hot. The motor hit a max of 120F with ambient about 77-80F. I might put a 16T pinion on to see how it performs with that (I want a little more top speed).
SETUP:
Hobbywing EZRun 60A ESC
Hobbywing 17.5T 2400kV Motor
UBEC 6V/3A
Graupner Plastic Motor Mount (cut to fit)
13T Pinion
HPI RX (Kyosho one died)
HPI E-Savage wheels/tires (~5.4" diameter, drilled)
12mm to 14mm hex adapters (drilled)
Ofna Yellow (Medium?) truggy springs
3s LiPo
