Bad Karma
04.05.2009, 11:39 PM
Originally Posted by crazyjr View Post
it's been a while since i was in school, but i thought it was pi X diameter, not 2pi X diameter. if you do single diameter you get 40.82. Still moot point because if everything else is right, you are still looking at 90 mph and still need further reduction or lower kv
metallover's right... It's 2*pi*r to get circumference or a circle
crazyjr
crazyjr's Avatar
04.06.2009, 02:05 AM
My bad, didn't see the radius, I assumed diameter
johnrobholmes
johnrobholmes's Avatar
04.06.2009, 08:09 AM
Another 5:1 would be your best bet. Can you pedal at 35mph though? search google for top hat adapter, you could put a 36t sprocket on your disc brake side and get all the geardown you need with your stoker setup.
Just going down in KV won't help, you will loose all of your power.
---JRH---
Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.06.2009, 08:19 AM
YEAH!! That's awesome. Not only will it work and be easy, but it will suit all me needs and it will be more efficient. I'm going to do some more research. Feel free to show me what I would need.
I just did some math and I'll need a 14/185 pinion/spur to do it all in one shot.
