pthunell
04.07.2009, 11:50 AM
The xl5 slipper looks almost identical to the revo slipper... If you are using a really old rustler as a base, you may have the old peg style slipper and the input shaft is different. If it has a hex shaped shaft it is the old style.
Good to hear that the a123 packs are working well. I think I made those out of a dewalt pack, been a while so I do not remember...
I have the newer style xl5 slipper clutch and spur. I was just trying to beef things up a bit. I think I'm going to go with the Jato set as you suggested. After search for 32p, I found what I needed, mainly through all of your posts. I hope you stick around for a while. You're a wealth of info.
Thanks!!
