whitrzac
Can't catch this...
whitrzac's Avatar
04.25.2009, 09:59 PM
6s seems a bit weak for this truck.. Might wanna use the 9l
but then I have to run HUGE 30+ teeth pinions. I should be able to fit a 4s on it, but I think it will be too much wight...
whitrzac
Can't catch this...
whitrzac's Avatar
04.27.2009, 05:09 PM
still no metal
04.27.2009, 05:55 PM
A 6s is a stout motor... I ran a 7s in a rustler way back and it could push that thing around easily. Plus it would pull over 100amps on 3s. Hope you have some good lipos... And a fan for the MM...
It pulled over 150 amps in my drag emaxx...
whitrzac
Can't catch this...
whitrzac's Avatar
04.27.2009, 07:54 PM
I'm using a 2s
IDK, but a tekin RX8 auta do the job
I have 1 esc between the maxx, and this....
whitrzac
Can't catch this...
whitrzac's Avatar
04.28.2009, 11:04 AM
well, aparently they can't get 7075, so they went and ordered some 3003(I think)....:grr rrrr: apparently its the closest they could get
whitrzac
Can't catch this...
whitrzac's Avatar
05.06.2009, 08:10 AM
the 3003 alloy still hasn't come yet
the 9l motor is going in the jato cus an RX8 combo is on its way to me for my maxx
will this motor have enought power to turn preaty much any gearing on a 4s??
found some 1/8 buggy adapters for it they should give the right offset, but everyone is out of stock
whitrzac
Can't catch this...
whitrzac's Avatar
05.12.2009, 01:46 PM
well, after 3 WEEKS the alloy has finally come in...
the chassis should be done tomorrow
I decided you use a novak HV 4.5 instaid because of the 1/8 shaft, its should have enough power
whitrzac
Can't catch this...
whitrzac's Avatar
06.16.2009, 06:18 PM
I'v kinda given up on the whole "corr truck" thing, but here are some pics
(2) protek 4000 15c 2s lipos
Novak HV 4.5
towerpro mg955
spektrum
18/56 gearing
1/8 buggy adapters
first time out I nailed the throttle and craped my pants uber fast
spegetty wires anyone??
how bout those pretty pink zipties holding the batts in
EDIT: without those huge caps on my range is only 100-150ft
whitrzac
Can't catch this...
whitrzac's Avatar
06.17.2009, 12:23 AM
did I mention its fast??
Differential Ratio: 1.9
Transmission Ratio: 2.066666666666667
Other Ratio: 1
Spur Tooth Count: 56
Pinion Tooth Count: 18
Total Voltage: 14.8
Motor KV: 5000
Tire Diameter (inches): 4.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.11 : 1
Total Ratio: 12.2163 : 1
Tire Circumference (inches): 14.45 inches (367.06 mm)
Total Motor Speed: 74000 RPM
Theoretical Maximum Vehicle Speed: 82.9 mph (133.16 km/h)
Effective KV Value: 5000
06.17.2009, 04:22 PM
That looks decent, but invest in a better ESC and go to 2s and gear up.
whitrzac
Can't catch this...
whitrzac's Avatar
06.17.2009, 08:08 PM
I'v got an RX8 in my maxx, but for $25 for a working esc and motor...
haven't had any heat probs yet, but then again I havent ran it for more than 5min...
but on a 4s that motor sounds wicked and 2s is just too slow
