Always Dreamin
04.12.2009, 03:55 PM
If only i had $1,000 to spend on R/c.... Nice truck.
tonkabilly
04.16.2009, 01:26 PM
Just waiting for the Medusa to show up to see if this set-up with work or not. May have to get new Lipo's or a new ESC. I gues I can tack this up to putting the cart before the horse and a learning lesson. Bought everything all at once without seeing if it will all fit. Got too excited i guess. Will post more pics when the motor gets in and go from there.
What are my choices on a smaller ESC? I have looked at the MGM's but they seem to be a bit to expensive. Anyone have quark's that run well. Have seen the Monster Pro and it is small enough. Just don't know how good it is.
04.16.2009, 01:31 PM
Mgm and the MMM are about the best bet for a reliable 6s esc... Neither are that much smaller than the HW you already have. The quark is good for 5s max, even though it is rated for 6s. Basically the same internals as a Mamba Max...
I would mount the esc above the tranny myself, and hopefully you have enough room beside the motor to fit the 6s packs you have. What are the dimensions of the 6s lipos you have?
tonkabilly
04.16.2009, 01:43 PM
The packs are 160mm x 51mm x 46mm. They just fit in without touching the spur. Have maybe 1/2" to spare. The biggest problem is the width. I am now seeing what you said about them being too close to the motor. Once I get the Medusa in that will be the determining factor as to what needs to be done.
04.16.2009, 02:41 PM
Well, you can put them in on their side, so they will be 46mm wide. The medusa is 36mm wide. If you can put the pack in and measure the distance between the center of the spur gear, and the edge of the pack where the motor would touch it. I should be able to calculate what distance you have left, and we will see what gearing you could run.
Also, can you list your motor and tire height again, and if you plan to run the 2 speed and mech brakes, or lock it in either gear? That will help with figuring the correct gear ratios...
I had to do this with my flm chassis and ended up with the 52t spur to get adequate clearance for the lipos.
tonkabilly
04.16.2009, 04:30 PM
Will try that when I get home from work tonight and see what we get. As for the spur, I was already planning on using the 52 just for that reason. Have plenty of 47, 49 and 52T spurs with a 14, 15, 16, 17 and 18 pinion already so I do have some options on this.
Thanks
04.16.2009, 10:51 PM
Thanks
Just let me know, Thanks!
