skellyo
skellyo's Avatar
04.13.2009, 01:59 PM
If you want to run 50mph, you're going to want to go 6S lipo and run something other than the stock tires. Geared 20:44 (stock gearing) with 2 X 3S 25C 4900mAh Neu Lipos and Pro-Line Badlands, mine went 53.8mph. Dropping to 19:44 on 6S may still get you to 50mph too, depending on tire ballooning. Anything less than 6S and you'll have to gear up, which I wouldn't recommend doing unless you're dropping to a lot smaller diameter tires.
