the provided pinion gear will be 8mm bore for a 8mm shaft but i think you can get a bore reducer on the RCM store that can reduce the pinion bore from 8mm to 5mm. so you could go with either shaft size although i would recommend using the 8mm just from experience with my own 1/5 conversion and the amount of torque on the Neu 22xx motors. in my opinion, the slightest mistake in gear mesh or chassis flex would easily snap a 5mm shaft on these large, heavy conversions.
The smooth motors allow more gearing possibilities. The conversion kit will likely have a mounting option for a fan over the motor for cooling.
I too am curious how that ESC would work - it looks good on paper. :)
Turnigy used to buy in Hobbywing ESC and sticked their name on it... So i would recommend u to buy the Hobbywing Platinum 120A HV ESC... this will give u truck load of power
It would probably work, but if you want a whole lot of speed they're going to run hot. What kind of peak power output do those have? I'm guessing 1,500 watts, so two of them should be OK if you are careful with your gearing.
