jhautz
jhautz's Avatar
04.15.2009, 06:07 PM
for 5s you want a custom setting of at least 15V. I personally prefer running a 16v setting to give it a little buffer. It keeps the battery healthier longer if you dont run it down all the way.
If it didnt puff and you were able to charge it back up the battery is probably OK. But fix that LVC setting before you run it again.
to make it...
or break it...
Silent...But Deadly
Mamba Monster cut off
Chris Corbett
Mamba Monster cut off - 04.15.2009, 06:18 PM
THanks for that. I assume the custom cut off is an option on the Castle Link? I have the usb and downloaded the software but for some reason it is not reading the esc so I programmed manually.
Do you need power to the esc and switched on to link it?
It did work once but not this time!!
Jeremy1976
04.16.2009, 12:18 PM
You do not need the power on to get it to work. Just plug it in.
