RC-Monster Captain
12.17.2005, 04:21 PM
Okay, what about the bearings that come with the RacrX and the UE cvds? are they also equal in size?
Nice to meet you!
12.17.2005, 05:33 PM
do you plan on getting the 8mm cvds? or the 6?
RC-Monster Custom
12.17.2005, 05:48 PM
6 mm cvd's will fit the bearing's that come with the racer x kit. 8 mm cvd's need bigger bearing's.
RC-Monster Captain
12.17.2005, 07:22 PM
Okay, everything seems fine till now. Let's talk about the drive train a bit more. The forward only conversion from Unlimited Engineering seems a good Idea for the e-maxx, however, is it going to save me any trouble with the G-maxx single speed conv. I mean, does it fit in the g-maxx single speed conversion without any modifications like cutting the out put front shaft of the FOC? what modifications am I going to do if the FOC does not fit in the single speed kit?
Nice to meet you!
12.17.2005, 08:05 PM
with a e-maxx there is no reverse servos like the t-maxx. the tranny will operate in forward and reverse with no additional gears. thus, you can reverse the diffs and tranny to conpensate for weight distribution, ect. all you need for the tranny is the flm cnc'd half, mikes idler, and the gorillamaxx single speed conversion, as well as the stock gears in the rest. also, i would stay away from the lightweight input and output shafts. the only thing i would do is get the lightweight idler shafts since they do not move and the idler only spins on them. although you will only save a few grams.
RC-Monster Captain
12.17.2005, 09:30 PM
Saving weight is not my point. I just read about these steel gears made by ue and I thought it would be a good idea to make the whole drivetrain beefed up with metal gear...opps..I mean metal gears. So if I'm to use a high powered brushless setup, is it not a good idea to use the FOC to guarantee the safety of the drivetrain?
Nice to meet you!
12.17.2005, 09:33 PM
Its ok, you wont need the FOC conversion to beef up the tranny, all it does is save you a couple of grams of weight and eliminates reverse, these gears are intended for racers.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
RC-Monster Captain
12.17.2005, 09:39 PM
If I dont buy it, then I'll surely save myself some money, but are you truley sure its unneeded? Mike did not recommend it as well.
Nice to meet you!
12.17.2005, 09:42 PM
Its unneeded in a g-maxx 1 speed, just keep reverse and save yourself some money and hassle.
Losi 8ight e
RC-Monster Captain
12.17.2005, 09:45 PM
Okay, you saved me this time, indeed. The wheels and tires, what do you recommend me to use?
Nice to meet you!
12.17.2005, 09:46 PM
The FOC is only used in nitro. It will NOT work with the emaxx tranny. REverse will be handled by your speed control. You can choose to program with or without reverse.
RC-Monster Captain
12.17.2005, 09:50 PM
Right, I completely forgot. Whew, almost going to take it. Thanks guys. How about the rims and tires?
Nice to meet you!
I reccomend to get 23mm dace or pro-line(im gonna use pro-line just cause they cost alot less) adaptors and get wabash rims, on 40 series crime fighters or bow-ties.
Losi 8ight e
RC-Monster Captain
12.17.2005, 09:52 PM
The adapters that come with the Ue 6mm cvds are not useful with the 23mm tires? the ones that Mike has.
Nice to meet you!
12.17.2005, 09:54 PM
No, they are not useful with the 23mm tires, as the hex hub the 6mm ue cvds come with stock sized hubs.
Losi 8ight e
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
