$70 120a esc
Joey
The Big Cheese
Joey's Avatar
$70 120a esc - 04.20.2009, 09:51 PM
Found this at hobbycity, anyone know anything about it?
$70 USD
120A max 240A burst
2-6 lipo
Forward, Brake (none, soft, hard), Reverse
Timing control
LVC (adjustable)
Built in BEC
Doesnt seem to have throttle curve adjustment or punch control...
http://www.hobbycity.com/hobbycity/s...hless_Boat_ESC
Heres an 80A 12s (!) esc for $80 USD.
Another steal... $110 100A 12S - great reviews too.
http://www.hobbycity.com/hobbycity/s...2S_BESC_(Ver4)
80A 6S programmable brake/throttle - $48
http://www.hobbycity.com/hobbycity/s...rogrammability
whitrzac
Can't catch this...
whitrzac's Avatar
04.20.2009, 10:04 PM
there boat esc's, meaning that they wont calabrate to a pistol radio.... I think...
turnigy=tenergy??
Constant Current: 80A
Burst Current: 180A
Resistance: .0007ohm
Battery: 5-12S Lipoly
*BEC: Nil
Motor Type: Sensorless Brushless
Size: 94 x 33 x 18mm
Weight: 81g
also, music on the lipo cells??
http://www.hobbycity.com/hobbycity/s...idProduct=2169
Joey
The Big Cheese
Joey's Avatar
04.20.2009, 10:16 PM
turnigy=tenergy??
Burst Current: 180A
*BEC: Nil
Weight: 81g
Dont see whats funny, using an external ubec or Rx pack reduces space and heat on the esc. Thats a GOOD thing!
1) Marine ESC. Read as: "Unless you water-cool it it will overheat."
2) The Sentilon is an AWESOME ESC if you have mechanical brakes.
3) If the lack of a BEC is the only problem, what's the problem?
Didnt realize the sentilon doesnt have brakes... that sucks it seemed like a keeper. Even with a fan the marine controllers overheat??
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.20.2009, 10:11 PM
brushlessboy16
brushlessboy16's Avatar
04.20.2009, 10:18 PM
Using an externam BEC is besides the point on a marine esc.. as you can see it has no heatsink and will overheat as stated.
Joey
The Big Cheese
Joey's Avatar
04.20.2009, 10:21 PM
Oh no heatsink... duh didnt catch that. You could always add one, wouldnt be hard to do with a thermal pad and small HS. Definitely worth it.
What's_nitro?
04.20.2009, 10:50 PM
I suppose you could flood the cooling tubes with thermal paste and then add a heatsink to the top of them... It's not the *best* solution but it would work if there is a flat surface under the heatshrink.
whitrzac
Can't catch this...
whitrzac's Avatar
04.20.2009, 10:59 PM
Not without a pistix adapter.
its not worth tryig to remove the water cooling plate from the esc and install your own.. just get a mamba max and mod it. same results with better parts support.
IDK, but I might pick up one of those hextronic things, I'v got a nasy habit of frying esc's before I race
whitrzac
Can't catch this...
whitrzac's Avatar
04.20.2009, 10:29 PM
its just how they worded it...
so will it calibrate to a pistol radio??
Joey
The Big Cheese
Joey's Avatar
04.20.2009, 10:36 PM
NIL! Idk if it'll calibrate, why do some controllers have trouble with pistol grips?
brushlessboy16
04.20.2009, 11:00 PM
I thought people were getting these to calibrate with pistol radios. Just gotta go through the steps........ I'm going to search.....
Joey
The Big Cheese
Joey's Avatar
04.20.2009, 11:04 PM
Well, it was a nice thought! I cant tell if the hextronics has a heatsink..?
What's_nitro?
04.20.2009, 11:08 PM
The HexTronik has a heatsink. It's that thin aluminum plate held on by the heatshrink...
04.20.2009, 11:19 PM
DOES NOT NEED PISTIX
shame on you, Ben for writing untruths
Search people!
