Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
04.23.2009, 03:37 AM
You said "a" 2S and/or 3S battery...why not a pair of 4S, 5S, 6S, or even 3S packs wired in parallel? You will get the right voltage, plus double or more run-time! What's the max voltage input for the Mamba Max? Whatever it is, buy two packs, each with the same voltage as the max input of the MM and run them in parallel...that way you could get a minimum of 10,000mAh, and the is more than enough room on a Hyper ST 1/8 truggy.
-Chad
PM ME IF YOU HAVE THE BELOW:
