04.24.2009, 07:48 AM
Sometimes it works if you turn the pinion around and have the screw side on the end of the shaft.
If you've managed to bend that mount once it is only going to be weaker if you bend it back and if it isn't aligned properly you will only damage the spur and / or the motor bearings.
