nzdans
Choice Bro!
nzdans's Avatar
04.25.2009, 11:09 PM
Hey nzdans, what gearing are you using with the 8.5 motor?
I built it with 23/87 as the manual recommends 24/87 for 10.5 brushless. This was fine for the 2 (5000 mAh) packs I have put through it; I ran it with the expo on the radio on -50% although may try -60% next time, I took it for some high speed play in the grass and the temp was still fine.
1:4-ARX 540 MX bike 1:8 LST2 RB Mods Picco P3 , X2 CRT BL 5S , OTO T-258 road bike BL LiPo. 1:10-AE FT B4 GTB 13.5 LiPo & FT TC4, SC10 GTB 8.5 LiPo, ABC Datsun 1200 GTB 13.5. Aquacraft SV 27 BL boat
dezfan
04.26.2009, 12:56 AM
Built mine w/o issue. No probelm w/ the steering rubbing, no misssing parts, caught the typo on the rear links early, and my diff is like butta.
I'm addding about 6 ozs of weight to the chasssis as the SC10 is about 20 ozs lighter than the Slash and seems to need a little extra weight. Black grease in the diff, running 37.5 wt oil front and rear, gold spring up front, greens in the rear, front arms level (rtr w/ body installed), rear arms level (rtr w/ body installed), 25 degree castor blocks, moved the ball end to the outer most hole on the rear hub to make the rear links as long as possible, added some FT T4 links, alloy hinge pin brace, CVDs, assorted stainless hardware, and a custom chassis brace added to the bottom of the chassis as I've seen a few chassis break.
Looking for a good 2200 KV motor to run, not sure maybe one from Medusa?
