The chassis can still flex and change the mesh. Plus the added weight of the clutch will wear the bearings out faster, no way around that. They should incorporate a front bearing block to support the end of the clutch assy. Sure it would add some weight, but if you are hell bent on having a clutch you are not all that worried about weight...
