brushlessboy16
brushlessboy16's Avatar
04.28.2009, 08:55 PM
Found it. Looks nice, but I can't tell if it runs a stick pack sideways or saddle packs
Unique Battery Fit
The Cyber 10B provides a unique RC 'first' with the drivetrain routing over the battery - the rear diff input shaft is angled up to allow the rear center driveshaft to travel just over the battery. This allows the fitting of several different types of batteries: stick, side-by-side and even hard-case Li-Po!
Batteries are held in place with a secure plastic strap and two height-adjustable body clips. There's even wire routing options for the different battery types, whether you are using stick packs with wires that come out the end of the pack, or Li-Po packs that use fitted plugs!
