George16
Supermaxx
George16's Avatar
05.01.2009, 01:38 AM
I drilled and tapped my GA bulks in order to capture the pins. This prevents them from moving and greatly reduces the chances of bending them. Besides, they'll break before they bend.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
RUSTED
06.15.2009, 12:31 AM
well i finally finished my emaxx and got it running yesterday , after 2 runs with the punch control set to 50% the spider gear got damaged it was the spider gears from a used kyosho mp777 then i changed the spider gears to the ofna titan spider gears and set the punch control to 80% and after 2 runs the spider gears stripped again although im pretty sure everything is meshed correctly.
my LHS sells kyosho inferno diffs and xtm diffs , which is better??
wat diffs r u guys using in ur hybrid bulks??
Kcaz25
Kcaz25's Avatar
06.15.2009, 01:47 AM
Thats odd and hard to believe! Emaxxter, a poster on TRX busted a HB Lightning diff in his Hybrids a few days ago
