Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
lutach
lutach's Avatar
05.02.2009, 01:36 PM
Originally Posted by ANGRY-ALIEN View Post
Hi Lutach, no waterjets here so far... So that's not an option for me right now.
Alien
Ok, all I know about carbon fiber and high heat is that carbon fiber burn pretty good. I've heard of people using a CNC machine and placing the CF under some sort of liquid to avoid all the harmful dust. If the same can be used with the laser then it might work.
Ryu James
Ryu James's Avatar
05.02.2009, 03:53 PM
i started out using a dremel tool with carbide tungsten bits to make my own carbon parts. then i found a CNC shop to do stuff. just make sure they use carbide tungsten bits. all other bits melt. also, the dust is extremely harmfil to breathe so you need to wear a mask when doing work with carbon. and i think it is better to run the bit at the slowest speed possible that still cuts efficiently. going faster only melts the bits or the carbon. i have found a slow speed cuts much better.
as for waterjets i havent tried it but i have heard that it also frays the carbon resulting in a very ugly part and one that most likely cant be used.
CNC is the way to go but may require some experimentation on your part.
there are some CNC shops that work with carbon all the time and really have a good system down of how to do it best. i have yet to find one locally but look around as i know there are shops that specialize in working with carbon and have already gone thru the trial and error.
Jammin SCRT10 Neu 1512 1y
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.02.2009, 05:10 PM
Thanks for all the help guys... Here's a little preview of what I am working on.
Alien
05.02.2009, 06:05 PM
That is a very pretty maxx.
