mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.10.2009, 02:34 PM
If your running an ERevo with the MMM your problem is surely with just the slipper. On 6S, that stock slipper has to be very tight or else it will slip too much and it will cook in half a second. That tight slipper doesn't slip enough to protect your drive train. Find a piece of aluminum, 2 to 3 mm thick. Make yourself an aluminum slipper ''disk'' pad to replace those three little Traxxas slipper pads. It doesn't even have to look good, it will work even if it's ugly. Just make sure the 6 little holes are in the right place. I have been bash and race testing this aluminum slipper disk on 4, 5 and 6S. I even tested it by setting it loose to try to make it fail. It did not fail, it just keeps on going. Here's a drawing of the disk in question. I tried to be as accurate as I could with the measurements. It really works and it lets you set your slipper the right way, loose enough so that it protects your whole drive train with no worries of the slipper cooking.
Here's a pic of the slipper disk after a lot of testing to see if it holds up. It does. The left disk in new, the middle disk is the test one and the right disk is just the stock steel slipper ring. The thickness of the aluminum slipper disk is still the same as new after almost 30 runs of 4, 5, and 6S
A boring movie of the kind of testing I did. Repeated full throttle starts.
No brain, no headaches.
