emaxxnitro
emaxxnitro's Avatar
05.10.2009, 10:27 PM
i did
blue input winding. broken winding as it enters the stator. burnt. you can see it in the pic
its a erevo
geared for 40mph.
mt badlands.
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333332
Other Ratio: 1
Spur Tooth Count: 52
Pinion Tooth Count: 19
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.84
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.74 : 1
Total Ratio: 14.2807 : 1
Tire Circumference (inches): 18.35 inches (466.01 mm)
Total Motor Speed: 32560 RPM
Vehicle Speed: 39.61 mph (63.63 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
808E
