Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
05.11.2009, 09:54 PM
The KB 45 motors are also 2 pole!
I want a look inside the HW motors myself. My buddy wants a budget buffy system, so he may get the HW80 and one of the motors, probably the longer model, should handle the heat better?
superek4
superek4's Avatar
05.11.2009, 10:13 PM
Yes it shld handle better heat but also draw more amps
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
05.11.2009, 10:16 PM
Seems like the difference between a L can and XL can feigao... Similar KV and the longer can will draw a bit more, but run cooler and thus more efficiently. So the amp draw ends up about the same... But the longer motor can run longer and will put out a bit more power.
littlegiant
05.12.2009, 06:22 AM
Actually the bigger can simply means tat it has a higher heat capacity for the same load. It doesn't necessary mean that the larger can has lower intrinsic efficiency.
Then again with a higher heat capacity, the motor runs cooler on the same load. And since the motor runs cooler, the effective efficiency is increased as compared to the smaller motor.
The larger can motor should be running at almost the same current than the smaller motor if both have the same kv and the vehicle they are run in is geared for the same speed.
nusti
nusti's Avatar
05.12.2009, 03:34 AM
I run the 2350 kv model in my emaxx with a HW150A. The first one i blew up in 5 minutes of runtime, probably a mounting mistake. I may have used mounting screws that were too long and that bent the inner wire wich in their turn shorted with the magnet. Or just a production failure :)
Anyway I got a new motor from HW (GREAT service) en used shorter mounting screws. I had three runs up to now. One to test if everything works and two runs at full power. Constant high speedruns/full throttle in a park on long grass. I use a 21/62 gearing and 2X 2s2p 5100maH 25C lipo packs. The runtime was 13 minutes. the motor didn't get warmer then 51 degrees centigrade. This is with a heatsink and fan. The lipo got handwarm as did the ESC.
I think it's a great motor for bashing and it's a cheap setup. For racing I will use a medusa
