MetalMan
MetalMan's Avatar
05.17.2009, 04:07 AM
That heat you experienced from running it unloaded is pretty normal... they are probably 90% ineffecient at no-load.
Made the adapter out of 1/4" aluminum, drilled/tapped 4 holes to 4mm thread/30mm bolt spacing, and drilled 4 holes to 3mm/25mm spacing. Then I cut it with a scroll saw and filed it to shape.
