05.18.2009, 12:07 AM
hmmmm I guess that's the way to go.
3.3 diffs...
What should I upgrade, inside the 3905, to make it as strong as possible, without completely overkilling it, or raising the bill to so high, I can only dream? :p
A 20 dollar 3905 diff from ebay is about as cheap as you can go. from what I can tell getting an al case for the 3905 diff is most likely the next best bet, as it will keep the ring and pinion from moving due to case flex. The 3905 diff internals look to be pretty robust, but you can always get the flm cups. Not too sure if flm make a case yet, but golden horizons do, if memory serves me correctly.
Next is the lst diff swap, but you have to change both and it will cost at least 100 bucks in parts.
