brushlessboy16
brushlessboy16's Avatar
05.21.2009, 09:13 PM
Still sounds like a slipping diff. Are the bearings good on the diff pinions? Worn bearings can allow enough deflection for the gears to get past each other. Any cracks in diff housings? Worn housings can do the same.
Housing is new. gotta check the bearings. I really hope it is something that simple.
Andrew32
05.21.2009, 09:55 PM
not sure of your trucks designs, but could it be the diff housing is flexing like the maxx?
my maxx makes the SAME noise unless im running 60% punch on low start...and im pretty convinced its the case flexing
