Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
tklemin
05.28.2009, 06:29 PM
cool I'll give it a shot.
Janezki
Avid Gear Crusher
Janezki's Avatar
07.10.2009, 10:15 AM
I've been a bit busy because of my work, so I haven't been able to enjoy my hobbies that much recently.
Anyway, since the last upgrade/date to Revo slipper this has happened:
Diffs converted to CENs:
Bought one of the last (?) Tekno Neus:
Bought two new lipos:
Changed tires to Badlands:
And had some serious fun and enjoyment from this setup.
Im using 18t pinion with the 49t MGT spur, so with 6S the truck is reasonably fast for offroader.
The motor is just pure insanity and I love it - should've got it right from the start...
It doesn't get hotter than 60°C (140°F) no matter how I punish it and lipos stay cool also.
Here's the data from Brian's calc:
Differential Ratio: 2.888888888888889
Transmission Ratio: 2.25
Other Ratio: 1
Spur Tooth Count: 49
Pinion Tooth Count: 18
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 5.84
Tire Ballooning (inches): 0.5
Motor Current Draw: 110
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.72 : 1
Total Ratio: 17.69444 : 1
Tire Circumference (inches):21.49 inches (545.81 mm)
Total Motor Speed: 47388 RPM
Vehicle Speed: 54.5 mph (87.54 km/h)
Effective KV Value: 2134.59
KT constant: 0.61 oz-in/A
Motor Torque: 0.35 ft-lbs
Final Torque: 6.23 ft-lbs
Final Power: 2442 watts (3.3 HP)
Unfortunately there's no video yet, I've been so excited to just drive.
