adrictan
05.31.2009, 02:32 PM
I see no reason you couldn't use a dremel to cut a slot parallel with the motor. You may have to take the whole center diff/transmission assembly out of the vehicle to do it though. Also try a butane torch style lighter and heat the set screw up a bit. The heat helps to soften the loktite.
even if I take the assembly out of the vehicle, my dremel will still not be able to reach the position of the grub screw. However, I do thank all those who've replied and I'll try the methods out. Thanks. :)
