Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.01.2009, 10:54 AM
I already have all the stuff, but I've ran into a gearing problem. I think I need another 5:1 reduction on top of my 2-3 reductions...... I think I'm going to find some scooter or something where the wheels are smaller.
brushlessboy16
brushlessboy16's Avatar
06.01.2009, 12:05 PM
I think all that chain is putting alot more drag and stress on the motor then it shoul.. just find a lower Kv motor possibly?
What motor is that btw?
Metallover
Metallover's Avatar
06.01.2009, 12:14 PM
There's a lot wrong with it... It's a failed experiement. I'm going to try to find a dead electric scooter or something like that now.
brushlessboy16
06.01.2009, 12:27 PM
ha we have a 550w electric scooter motor in a Powerwheels Jeep :)
06.01.2009, 12:31 PM
What about one of those inline planetary gearboxes? They usually are good for around 6:1. Maybe two of those "in series" to get a good ~36:1 ratio would make gearing much easier.
mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
06.01.2009, 07:15 PM
im planning on using this servo tester (suggested by brushlessboy16)
and myabe 2 orders of these for 6s 8000mah 10c for 80A cont and 120A burst for only $80
and this pinion. it has a large surface area and is cheap
now all i need is the tranny plate
-mikey09120
Thinking.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Thinking. - 06.01.2009, 07:24 PM
You already have a pile of gear there that needs to be put to good use. Don't scrap that project so easily yet. Just take a step back and rethink your approach. With what you have there you can still make this a very cool project. You may need to go a slightly different direction with your gearing or even your drive setup to accomplish your goal, but it is still possible to get her done.
Maybe a belt drive with a spring loaded clutch assembly, or like suggested my BrianG using an inline planetary gear setup to get your gear reduction would be a better choice. There has to be something that you can do to make it work fairly well. Don't give up on it yet.
SUPERMAXX YOUR LIFE.
brushlessboy16
06.01.2009, 07:23 PM
http://www.hobbycity.com/hobbycity/s...idProduct=8296
http://www.hobbycity.com/hobbycity/s...idProduct=8373
way cheaper
Metallover
Metallover's Avatar
06.01.2009, 10:07 PM
I have the second one.
I am considering a friction drive to at least test. Either that or buying some parts made for this application...
brushlessboy16
06.01.2009, 10:10 PM
I have a big brushed motor if you like...
PM me if your interested in it.
443 Kv and a 50:1 reduction box.
Its the same physical size as a neu 2230.
If no i have to put this on my bike :)
Tempting.
JERRY2KONE
JERRY2KONE's Avatar
Tempting. - 06.01.2009, 11:10 PM
Hey what voltage is that motor? It sounds like an idea that wold work well in an application like an E-bike? And where did you get it? off of some household equipment, or junkyard, or some other application? I am curious about the motor to.
mikey09120
mikey09120's Avatar
06.02.2009, 12:44 AM
heres the ratios and rpms
this is with 24t motor pinion and 54t spur with 1.833:1 tranny ratio and a 30:1 ratio from outdrive pinion to wheel/tire rotation
2200kv castle neu motor on 6s lipo with MMM and 26in tire diameter
-mikey09120
brushlessboy16
06.02.2009, 12:01 PM
motor is designed to run 12v. but I have overvolted it to 36v. it can handle it. its designed to push 200lb robots. should have plenty of punch to move a bike.
Byte
06.02.2009, 12:48 PM
Can someone explain me how this thing works?
Metallover
Metallover's Avatar
06.02.2009, 12:55 PM
There is a pot (the knob) on the end. If you turn that it will turn a servo, or the throttle on the esc. It has a (iirc) 6v or 6s lipo input. You may want to make a rubber band/spring mechanism that returns it to neutral after giving it throttle. That's what I plan to do.
