Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.12.2009, 03:11 PM
The diameter of the spur gear on my tc3 is about 40mm. what's the diameter of your 44t spur?
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.12.2009, 03:21 PM
Dunno man. Dont have the car here with me. Figure that 44T 32p is equal to about 66T 48P. BrainG has the gear diameter calculator. 44T is equal to 36.5mm.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Metallover
Metallover's Avatar
06.12.2009, 03:29 PM
Awesome. Do you know off the top of your head what pinion you are running?
06.12.2009, 03:27 PM
44T 32p spur is 36.51mm diameter.
http://scriptasylum.com/rc_speed/_gear_calc.html
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.12.2009, 03:28 PM
Doh, I just edited mine.
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.12.2009, 03:34 PM
I use pinions from 9-12T count. With bigger pinions I use sensored/hybrid mode.
Metallover
Metallover's Avatar
06.12.2009, 03:48 PM
I'm thinking I could use what I have - My medusa 36-60-2000. yeah baby.
Gearing. I found if the spur/pinion are the same size, I should get around 88mph. I think 32p 44t pinion/spur should work; problem is finding the gears.
How can I make an adapter to run a spur for my pinion?
Differential Ratio: 2.5
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 35
Pinion Tooth Count: 35
Total Voltage: 14.8
Motor KV: 2000
Tire Diameter (inches): 2.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 2.5 : 1
Tire Circumference (inches): 7.85 inches (199.49 mm)
Total Motor Speed: 29600 RPM
Vehicle Speed: 88.06 mph (141.45 km/h)
Effective KV Value: 2000
KT constant: 0.68 oz-in/A
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.12.2009, 03:55 PM
The smallest 48p spur that I have seen is 46T, but it's doesn't have those diffballs holes.
06.12.2009, 04:33 PM
If you mesh the gears right you will not strip the 48p.
Metallover
Metallover's Avatar
06.12.2009, 04:44 PM
I'm not worried about gear mesh, but more my shaft size. I've got a 5mm shaft and 32p pinions are easer to find for a 5mm shaft; or can you find two equal tooth count 48p gears, the pinion with a 5mm shaft, the spur fitting in the tc3, and the two shafts about 35mm apart?
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.12.2009, 04:43 PM
I don't strip gears. But I hate swapping in new spurs when little rocks get in between the mesh of 48P gearing and locking up the motor.
BrushlessReady
06.14.2009, 01:21 AM
here are two cheap gyro's (i have the second one in my rustler)
http://cgi.ebay.com/Esky-Head-Lock-H...ayphotohosting
http://cgi.ebay.com/EK2-0704-Gyro-Fo...3%3A1|294%3A50
Metallover
Metallover's Avatar
06.14.2009, 05:30 PM
Drove the car for a couple minutes with a 8-cell nimh pack. Don't have a charger for that pack so once it's gone its gone... It drove pretty good and it was pretty fun even at not so quick speeds. Once I split my 4s zippy I'll have a copule 2s packs I'll probably run in a parallel so I can still run them in a series later.
Temps were ~110-120 both on the motor and esc; battery was cold. I think the front diff is stripped or loose; I'll take it apart probably tomorrow or later tonight. I'll clean off my work bench first.
Metallover
Metallover's Avatar
06.14.2009, 11:13 PM
Are you the shooter of that video? That Channel? I've watched a bunch of those speed run vids... Any tips or tricks?
speedracer1129
06.15.2009, 08:04 PM
Negative. I was the one radaring it. I was actually the one who came up with the setup 1 year and a half ago working with some help from CC. We have been running high spped cars for several years but I wanted to build a 100+ car with 100% off the shelf parts. Nothing custom!! The TC4 was the ticket!!
As far as tips, all I can say is that the power is available. The key is the setup of the car. Suspension and body choice are very important!!
