littlegiant
06.09.2009, 10:54 AM
Originally Posted by NovakTwo View Post
We separate the shafts from the magnets by putting the rotors in one of our ovens at extremely high heat.
This heats the epoxy until the shaft can be pulled out.
Wun the magnet get demagnetise?
NovakTwo
Senior Strategist
06.09.2009, 10:59 AM
Yes. That's why we separate them.
Then we can re-magnatize the magnets.
Novak Electronics, Inc.
littlegiant
06.09.2009, 11:25 AM
OoooH I guessed that part right.
Anyway how do you magnetise a demagnetised magnet?
J57ltr
06.09.2009, 02:01 PM
With a strong magnetic field. When I worked for Western Atlas we had a Zapper that we plugged in and set the magnet into a cradle that was surrounded by an electromagnet. It was set for about 3 large pulses that would take a AlNiCo magnet from being so weak that it couldn't pick up a paperclip to strong enough to pick up a 25 lb weight. I am sure it would be the same type of operation but the poles would be oriented so that the N and S are perpendicular to the length of the rotor. I would like to know exactly how this is done also. Things like how many amps @ Volts and how many turns are in the electromagnet and what gaquge the wires are.
Jeff
I suggested using Locktite for retaining sleeves to glue a rotor back onto the shaft after it came loose to a friend of mine and it worked great, but you have to heat it to over 400F to get it to seperate.
NovakTwo
Senior Strategist
06.09.2009, 02:22 PM
With a big, expensive machine.....
