zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.10.2009, 02:35 PM
Why don't you just reconfigure those batteries as a 6s pack 5000mah pack? You will have lot's of power, but as long as you have throttle control, you will have great runtimes, I'm sure up to 30 mins... that's what ppl here get, and that's what I get on a 1512 3D (1700Kv.)
zeropointbug
Z-Pinch racer
06.10.2009, 02:37 PM
And gear down of course, I am 100% certain you will have a cooler running setup, longer runtimes, and loads more power available.
jzemaxx
06.10.2009, 02:40 PM
I plan to series them to 6S instead of running 2 3S's parallel. I figured a KV of around 1100-1500
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Finnster
KillaHurtz
Finnster's Avatar
06.10.2009, 11:18 PM
I too think your runtime sucks as you are spining the motor too slow, and having to prolly pull a tall gear to get speed. Your runtimes should be quite a bit longer for that much batt.
6S, then use a 1300-1600 kv. I had a 2Y on 8S, and really that's the min you'd want to run. I don't like to run high rpms (~40K+) but its better than running too slow (<25K.) My 2.5D on 5S is quite fast enough and gets good mileage. A 3D on 6S 5000 packs should run quite a long time, more than 23mins for sure.
