Freezebyte
06.15.2009, 09:46 PM
Your griping about $3 for high quality, hobby grade power plugs? Welcome to hobbys. No one said this shit was cheap. This is even more ironic coming from someone who lives in one of the most expensive cities in the nation.
Perhaps Nikko is more your thing?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
06.15.2009, 10:40 PM
Jeeze, you are just full of wisdom, and are a real asset to the RCM community. where's the rollyeyes?
I've used some of those ribbed hobby city ones, and some I got from a vendor at the ihobby expo. (lightning power) So far, I haven't had much issue except that the plastic is softer and melts much easier than the genuine deans... and the fit and finish is not as good.
I use them mainly for things like charge leads, or on my kids cars, etc... not usually for my main race car and packs. But I have used them when I was out of deans, and never noticed any power losses or heat issues.
I think the chinese packs that come with connectors are often HORRIBLY soldered... with big blobs of solder etc. I would recommend ALWAYS re-doing the solder work on these packs. Besides, the lead wires are always longer than needed, so they should be shortened anyway. I think all the long wires and crappy solder joints are a common cause of problems people have with high power electric cars.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.16.2009, 12:23 AM
I'm not bashing Deans connectors, buut, what is so high quality about them??
It's just two pieces of metal melted into a blob of plastic.
Freezebyte
06.16.2009, 11:45 AM
Go ahead and use Tamiya connectors then and watch what happens.
scarletboa
scarletboa's Avatar
06.16.2009, 02:50 PM
been there, done that (mostly for shits and giggles)
i was surprised when they were able to handle my rustler vxl on 3s, but i made a funky adaptor for my savage and they melted within 2 minutes.
zeropointbug
Z-Pinch racer
06.16.2009, 04:15 PM
Why are you still comparing the Deans to Tamiya's? Yes, we know they are worlds better... as far as I can read, we are comparing to bullet connectors.
