Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Ryu James
Ryu James's Avatar
08.05.2009, 03:06 AM
that speed control looks great with the large heatsink. that should make it much easier to cool. does it have pipes for water cooling also or is it normally cooled with a fan in the boats?
and i wouldnt worry about the 12awg wires. i amsure they will be more than sufficient.
Jammin SCRT10 Neu 1512 1y
KaztheMinotaur
KaztheMinotaur's Avatar
08.05.2009, 05:47 AM
No pipes for water cooling which surprised me since it is marketed as a boat ESC.
E-sav
08.05.2009, 10:04 AM
Would like to point out that quite a few lipos that can flow 150 amps constant have 12g wires. I don't think you'll have issues with the wires on that esc. If you do, you need to re gear cos you'll be pulling some serious amps!
Great looking truck by the way, real tough.
08.05.2009, 01:21 PM
You need to find the area of the wire. Just using 12 "units" as the diameter because it's 12 AWG.
Area = pi times Radius squared
pi(12)^2 = 452.41 units
pi(6)^2 = 113.10 units
The 6awg is 4 times as big as the 12awg as the area of a circle increases expodentially.
To find twice the size of 12awg, take the area, 113.10, and multiply it by 2. Then take the resulting 226.2 and divide it by pi. You'll get about 72. Find the square root of 72 and that's the gauge wire that is double 12awg.
If my assumptions are correct, twice the size of 12awg is 8.51awg. So 7 or 8 gauge wire will be twice the size of 12awg.
Yes, I do feel pretty cool.
DAAAAAYYYUUUUMMM! That's like BrianG status right there!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.05.2009, 01:23 PM
That was pretty good, but this is easier. http://hyperphysics.phy-astr.gsu.edu...es/wirega.html
08.05.2009, 02:05 PM
Yeah- that's pretty easy.
KaztheMinotaur
08.05.2009, 03:42 PM
Anyone have any ideas for timing for the 2215 motor?
nitrostarter
nitrostarter's Avatar
08.05.2009, 01:02 PM
The boat guys use it as is, as well as adding cooling plates and tubes inbetween the FETs and heat sinks.
N. Rustler conversion
08.05.2009, 03:48 PM
If it has the same number of poles as a 15xx size, then a couple notches above the minimum setting (low-medium timing) would be a good starting point.
On the .rar format issue, use winrar file extractor:
http://www.win-rar.com/download.html
KaztheMinotaur
08.05.2009, 04:00 PM
He was able to email me the .exe file instead.
Thanks.
nitrostarter
08.05.2009, 04:51 PM
The 15xx and 22xx are both 12 slot 4 pole motors. As for Timing, you are running a Wye wind which is usually more responsive to timing changes. I would suggest starting at 10 degrees and work around that. May ask for more, or may be hot and need less. Watch your temperatures.
KaztheMinotaur
08.06.2009, 01:10 PM
Since there are dual power leads would it be worth while to plug 1 battery into each ? Or should I combine each pair of power wires into 1 bullet plug and series 2 batteries together?
nitrostarter
08.06.2009, 01:15 PM
You must connect the 2 power leads from the esc to a common connector. Then you can go about series or prarllel connections. You must have the same voltage going to both leads otherwise catastrophe.
KaztheMinotaur
08.06.2009, 04:32 PM
Thats what I thought.
Ryu James
Ryu James's Avatar
08.06.2009, 04:59 PM
so check it out all! i got my spur gear from the CNC today. this is the 36t and the 40t will be done tomorrow. then i will take them to another shop to get hardened. but they turned out perfect. and the motor mount is coming soon.
the 36t works perfect with the standard setup. it fits in the chassis groove for the spur and clears the chassis by about 2mm. the 40t will only require to flip the diff mounts upside down which gives the gear more height off the chassis but still will sit right perfect in the chassis groove and sit a few mm off the bottom. here are some pics of the 36t.
here is the milled area 6mm deep with 4 drilled holes for m4 screws. holes still need to be countersunk.
Photobucket
here it is mounted up:
Photobucket
Photobucket
Photobucket
Photobucket
as you can see the gear spins freely.
Photobucket
i am hoping, hoping, hoping he gets my motor mount done tomorrow!
